Possible Pole/Monitor Barn Build Idea
   / Possible Pole/Monitor Barn Build Idea #11
<snip> I am thinking of utilizing local wood that I can saw up roughly with a chainsaw mill Main center supports here show to be an 8x8 actual dimension with 4x4 actual dimension for the side shed uprights. Plan is to utilize gravel bottom until we make more for a concrete slab.
<snip>
Thanks,
Jclaudii!
How much CSM have you done? What's your labor force?
CSM is good for remote locations where you can't get other equipment, but if you can pick up a used Woodmizer, Lumbermate, Timberking etc. it might be well worth it.
I've two Stihl 660's and an 088 with bars up to 42" I used for CSM. I now use them to prepare for my LT10.
/edit - Also have 2 Alaskan Mark III's for CSM
   / Possible Pole/Monitor Barn Build Idea #12
Hello,
I think the side wings are too narrow at 9.5 feet. I would go at least 12' wide and then you could get a decent size garage door on the front of each wing. Just my thoughts....good luck !!!!
MFWD
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
*Selling at Royal Auction Tampa, FL Location* Power, doesnt crank. Hrs N/A (A59228)
*Selling at Royal...
