Post frame construction questions.
   / Post frame construction questions. #31
Hey Eddie, that Armour Metals is in my hometown, Augusta, GA! A good reputable company. I've been there, was just there a couple of months ago. They do good work.
I'm also needing another roof on me place to put some more of my junque under... A man can never have too many roofs on his place.
   / Post frame construction questions. #32
Looking to do a 40 x70 x12, all living space inner framing with 2x4's & 2x6 ceiling joists. My nagging unknown is the SLAB, yes 5" thick with rebar on 24" grid, BUT are you guys going flat slab ? Or dug out beams poured in slab. EVERYTHING else I am good with. What say ye ?
   / Post frame construction questions. #33
Jack where you at ? Would love to check it out !
   / Post frame construction questions. #35
Might I suggest going to 72'
72 is kinda a magic number. It works out nice and even with every common building material dimension. 16", 24", 3', 4', 8', etc. So if you go 16" or 24" studs and insulation, it works. IF you go with 4x8 sheathing, it works. 16" block foundation, it works, 3' metal siding, it works.
   / Post frame construction questions. #36
16" block foundation ? Never heard of one called that please elaborate.
   / Post frame construction questions. #37
Like how a house basement is built.....out of 8x8x16 concrete blocks. You dig a footer below frost, pour some concrete (thickness and width determined by a number of factors), the lay 6 or 7 row of block on top of that. That leaves a few block sticking out of the ground, in which you stick frame on top of that.
40'x72' dimension works out to not have to cut block except around doorways.
   / Post frame construction questions. #38
Ahhhhhhh, thanks for the info and picture to back it up.
   / Post frame construction questions. #39
Not sure what you mean by a 5 inch slab? The two most common sized lumber for the forms are 2x4's which give you a 3 1/2 inch thick slab. This is the most common thickness for a house and driveway. Or you can use 2x6's for the slab and it will be 5 1/2 inches thick. This is a lot more money for concrete that will not give you any benefit for a house. If you are going to be bringing in some very heavy equipment, then the thicker slab might be worth the expense, but if that's the case, going with a 5 or six bag mix should be considered, along with setting your rebar on 18 or 16 inch centers.
All your load bearing walls need to be at least a foot deep in my part of Texas. I'm guessing it's similar where you are. Basically you just dig around the perimeter with a shovel the full depth of the shovel and pile the dirt onto the outside of the form boards. With interior walls, it's usually a good idea to dig a trench for them too. If you have a really long span somewhere that will have a high point load on where the boards support it, digging a 2x2x2 footing will handle most loads.
Inside every footing, go with at least half inch rebar, which is also called #4 rebar. In some places it has to be 5/8's or 3/4's due to earthquakes or hurricanes. Up to you what you use if you are outside city limits and there is no code.
It is extremely rare to build with blocks here in Texas.
Are you going to have an island in the kitchen with a sink? Be sure to use PEX for that. You never want to run any water lines under a slab, but if you have an island, you don't have a choice. PEX is the best material for this. Just be sure to have it at least a foot under the slab and use water line insulation around it where it comes through the slab. Run all your other water lines through your walls or attic space. Be sure you have lots of insulation over the water lines if they are in the attic, it gets hot here in Texas up there!!! :)
   / Post frame construction questions. #40
With such a low frost depth, I assume a monolithic pour is more common?
We gotta get down 36" or so around me. Makes the cost of a monolithic slab pretty high. And makes the extra labor of the block justifiable
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
159116 (A60430)
159116 (A60430)
1995 Polaris 300 Explorer ATV (A59814)
1995 Polaris 300...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
