Post Hole Digger + Shale = ?
   / Post Hole Digger + Shale = ?
I have a smaller pasture I want to fence in soon. I will probably lay out the fence line and just rent a 3-pt pto setup from the local shop for $75/day. I should be able to bang out the whole pasture (probably about 20 posts) in a day's rental if everything goes halfway smooth.
If that goes well, I will consider what I need to buy to do the larger and future projects.
ac
   / Post Hole Digger + Shale = ? #12
you need to rent a belltec hydrolic posthole digger.then you wont have a problem digging in your rocky ground.i priced the belltec a few years ago an they wanted $4500 for it.
   / Post Hole Digger + Shale = ? #13
ac
Once you see what auger bits cost and replacement cutters you may find it is cheaper to rent than to buy. Typically a post hole digger just takes up space and doesn't get used alot on 13 acres. Once you fence the property it sits there. $75 a day is reasonable imo.
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
1989 22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
1989 22ft T/A...
2015 Kubota KX91-3S2 Mini Excavator (A52377)
2015 Kubota...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
2019 TAKEUCHI TL8 SKID STEER (A52705)
2019 TAKEUCHI TL8...
