post hole digger stand
   / post hole digger stand #11
This is a simple one i built. I can now move it with my tractors forks and can easily attach it... PLUS it was CHEAP top build with scrap wood. Mines a Speeco with hydraulic assist . ...
Is your digger a facory original or did you add the cylinder to it?
How well does it work and what kind of ground do you dig in?
   / post hole digger stand #12
I used the corner of my pole building. I put a 4 foot 4x4 diagonally on top of two girts at the corner and fastened it to the girts with screws. The girts are about 6 feet high. Then used a 1/4" chain, with a hook, over the 4x4 to hang the PHD. The chain allows for adjustment to fit. Works good.
   / post hole digger stand #13
Is your digger a factory original or did you add the cylinder to it?
I added the pressure down system to it earlier this year. Ground is decomposed granite and is hard digging. The hydraulic assist adds a few hundred pounds down pressure and it really helps me dig the holes when the ground is dry.
   / post hole digger stand #14
This is the simplest design I have ever found, I am definitely going to try this, thanks.
   / post hole digger stand #15
This is a simple one i built. I can now move it with my tractors forks and can easily attach it... PLUS it was CHEAP top build with scrap wood. Mines a Speeco with hydraulic assist . I used to leave the auger installed, but it always gets in the way. It hooks up in a few minutes so what the heck. Plus now im forced to verify that the bolts are tight. I was also thinking of making a grade 8 pin to replace the bolts. And use latch pins to secure. Would be real easy to do, but i am a lazy sort. Will be a winter project i guess
How does that hydrolic assist work???
   / post hole digger stand #16
It has positive down pressure, but automatically releases all pressure when i raise the boom. Its a single acting cyllinder. Its amazing on how much it helps get hole started.
I used to get stuck trying to get holes started, would have to stop snd use pry bar to disloge a rock or get a small hole started. Or have someone help push down on pry bar to assist (very dangerous). With this .... No more problems.
I have to use it to set new fence next month on the 10 acres we purchased accross the street last month. Will get a workout
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2023 Ford F-150...
2016 BOBCAT S850 SKID STEER (A52705)
2016 BOBCAT S850...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
