Power Barrow for BCS Grillo and Gravely
   / Power Barrow for BCS Grillo and Gravely #1
oldmech
Quebec
Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
I just finish. Turn very tight less 7 ft. Very easy to dump. Very light. Engine torque transfert weigh to tractor So I think could be go with load on very steppy hills. I do not try again with heavy load. 6 cu. ft. and may be 300-400 lbs capacity. Thanks and Good Luck! Oldmech
   / Power Barrow for BCS Grillo and Gravely #2
Looks like another great job.
I don't see any levers like a wheelbarrow to dump the material.
Could you please explain what makes it easy to dump?
Hi! On pict no1 Look in center on the square tubing they are a Knob (From a old door) you turn right or left this unlock and with one hand you lift the square tubing corner. Very easy because Good balance near neutral for close you pull down .Lock as a door Later I could add other pictures Thanks! Oldmech
   / Power Barrow for BCS Grillo and Gravely #4
O.M.: Thanks for posting your latest triumph. I am new to the small equipment world and have never been a fabricator so I appreciate your work. What will you build next?
I need to move soil and I wondered if you had considered adapting something like
Gravely Tractors - Utility Scoop - StevenChalmers.com
to your grillo. Perhaps you already have the gravely utility scoop for your gravely tractor.
Have you considered adapting a soilmover to your gravely or to your grillo?
see soilmover on High Ridge Tractor Parts
Thanks
Hi! I found some defects on my power barrow. First When go front the empty box go in air by engine torque and side turn over. I add one angle limiter on swivel hitch. Second the 3/4 in. dia. king pin bend with heavy load on very bad ground I go for 1 in. dia. Also I change fork angle from 3 in. (caster) to 4.5 in. (5or 6 in. could better) Less hard to turn with heavy load. I like it ! Turn very short easy to dump. Go anywhere hill uneven ground mud etc.. Load transfert by engine torque is impressive. I use it a lot now. Good luck ! Oldmech
   / Power Barrow for BCS Grillo and Gravely #6
Good job there oldmech,, your creativity and resourcefulness are amazing.
   / Power Barrow for BCS Grillo and Gravely #7
Good job, thanks for posting it...
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2019 MACK ANTHEM AN64T  TANDEM AXLE SLEEPER (A56138)
2019 MACK ANTHEM...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
