Branson 4020R
Hydraulic System
Type Position
3 point hitch Category 1
Lift capacity (lbs.) 3,306 (1,500kg)
Pump capacity 13cc / 7cc per rev
Pump flow 8.9 gpm / 4.8 gpm
Install a hyd gage in the IN port of the log splitter valve and if you have pressure, it could be closed center.
If it is open center tractor and open center log splitter, there should be flow, but no pressure at the in port of the log splitter valve.
Open center log splitter valve should have hyd flow all the time.
Closed center valve on a log splitter will have no fluid flowing in the neutral/spring center position.
There is a good reason for not pressurizing the OUT port of a log splitter valve, as the OUT port should have no more than 500 psi pressure, so the OUT hose to tank would be ideal.
