Power Service = warmer engine
   / Power Service = warmer engine #21
Use of fuel conditioner will not raise your coolant temperature. If so, than there is something wrong with your cooling system. I also us PS and Howes and there is no difference on coolant temperature here in any of my Diesels. It does start better tho in the wintertime and keeps injectors clean and I get better power / fuel economy. As others mentioned, I'd check the rad and clean it, fan belt. I doubt it is the dangling ball in the termostat, otherwise your engine would run cooler that than barely in the green.
   / Power Service = warmer engine #22
I have a DX-55, and i can attest to the fact the gauge reads pretty cool. The gauge has a 'blue' section for cold, adn then a series of tick marks. I never make it out of the first tick mark past the blue, its always run there, no matter how hard you use it. Im just used to a temp gauge being 'in the middle' under normal operating conditions, like a car.
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2019 Deere 550K (A53317)
2019 Deere 550K...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
