Power steering cylinder...
   / Power steering cylinder... #21
I was going off what Chris said.
Like I said. If you owned one of these yourself, you'd better understand what's going on here. When I owned those Jinmas, the one with the front cylinder was tapped so the fittings would face either up or down. Mine were up. Chris concurred that his were up as well. However the photos posted by the OP clearly show that his cylinder is tapped so the fittings can face either front or rear. The suggestion is for him to rotate the cylinder so those holes face forward, then select the desired fittings to route the hoses up and over. Regardless of which type cylinder, either can be rotated on its bracket. Following that, the only difference is which fittings to select for routing the hoses up and over.
//greg//
Got caught up with a couple other things this weekend. Will post more about the change over mid part of next week..
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
