Power Steering Fluid, Ford 3000
   / Power Steering Fluid, Ford 3000 #1
cpcattleco
Elberta, AL
Ford 3000 diesel, 8-speed
I'm changing all the fluids on the Ford 3000 (not sure of year, 1970's perhaps) that I just bought. My power steering resevoir appears to have ATF or regular power steering fluid in it. I checked with the local dealer who recommended using the New Holland 134G spec hydraulic fluid (same as in transmission and differential). This stuff seems to be rather thick for power steering use. A couple local people I asked said they use power steering fluid because it's lighter and works better in the winter.??? If I don't change the fluid at this time is their any harm in topping it off with PS fluid?
   / Power Steering Fluid, Ford 3000 #2
G'day atf is fine in these systems it is what we put in them alll the time at work
Jon
   / Power Steering Fluid, Ford 3000 #3
ps fluid works.. atf will work if she don't leak too bad.
134 fluid is the proper spec though.. you can get it at walmart or tsc.. etc.
soundguy
Thanks guys for your advice and help!
   / Power Steering Fluid, Ford 3000 #5
let us know how it turns out for you.
soundguy
Power steering fluid is working fine. I've logged about 5 hours since topping off the resevoir and have no problems. Thanks
   / Power Steering Fluid, Ford 3000 #7
PS should work fine..
soundguy
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
