Power steering not working; Need help diagnosing (GC 2310)
   / Power steering not working; Need help diagnosing (GC 2310) #11
manual doesn't specify any bleeding procedure but does say air in steering system can cause steering issues. it specifically mentions excessive free play but I would assume it could also cause other symptoms.
   / Power steering not working; Need help diagnosing (GC 2310) #12
It seems to me that a gauge tee'd into a pressure circuit would show little to no pressure until the system has a "load" placed on it. In this case, the steering wheel would have to be turned. Might need 2 people if the gauge can't be observed from the steering wheel area.
But simply unhooking a line and plugging a gauge into the line or port and starting the tractor could/will "deadhead" the pump, possibly (probably?) causing catastrophic damage.
   / Power steering not working; Need help diagnosing (GC 2310) #13
Were you able to get the power steering fixed? The pressure line on my gc2300 blew and after I replaced it the power steering isnt working. Wondering if you had any tips.
exactly which line?
  • 2400_sterring_hydraulic.pdf
   / Power steering not working; Need help diagnosing (GC 2310) #15
Maybe air in system? I'll see if service manual has procedure for steering in few hours
I hoped that bleeding it would fix it so I even dropped the front axle to get access to the hydraulic fittings on the two way Cylinder that turns the front wheels and bled it. I can still turn the front tires but its Nowhere Near as easy as it was when the power steering was working
   / Power steering not working; Need help diagnosing (GC 2310) #16
Jeez I would still suspect air somewhere.
When bleeding you have someone turning orbital valve?
Wish manual talked about this more.
Maybe a local dealer has dealt with this and can give you hints?
edit: maybe "bleed" should have been done at return line (item 5) and not at the cylinder itself??
2021 CATERPILLAR 259D3 SKID STEER (A52707)
2021 CATERPILLAR...
HYD TREE / POST PULLER (A57192)
HYD TREE / POST...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
CFG Industrial MH12RX (A56469)
CFG Industrial...
UNUSED FUTURE CL100 40" - 10" CLAMP GRABBER (A57193)
UNUSED FUTURE...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
