Power steering uses hydraulic fluid?
   / Power steering uses hydraulic fluid? #1
Gray Hand
Kubota M4050
thanks for the diagram. Again for the 1985 kubot M4050; the owners manual says the place to check the power steering fluid is on the left side under the hood. Can't find anything that even resembles a power steering reservoir. Online it says the power steering uses the hydraulic fluid. Anyone out there have a M4050 and can verify this.
   / Power steering uses hydraulic fluid? #2
Workmaster 50 is the same. Looking at front, raise hood (workmaster) and it is near radiator reservoir. Radiator fluid is green (workmaster) and hydralic power steering reservoir is reddish (workmaster). See what color your hydraulic oil is and find reservoir under hood in front of motor that matches. A finger in reservoir will also tell antifreeze liquid or hydraulic fluid. Workmaster 50 uses engine oil, antifreeze for radiator and everything else is hydraulic fluid.
   / Power steering uses hydraulic fluid? #3
Follow the lines up from the hydraulic steering cylinder that operates the steering link. At the other end of these lines will be whatever pump serves that function.
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2022 Ram 5500 Rollback Truck, VIN # 3C7WRMDL3NG150900 (A54865)
2022 Ram 5500...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2014 Chevrolet Equinox SUV (A55758)
2014 Chevrolet...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
