Power Trac 1845 Report
   / Power Trac 1845 Report #1
Charlie_Iliff
Arnold, MD
Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
Today, I got to test a number of the attachments on the Power Trac 1845. I couldn't demonstrate any weaknesses or problems - other than, of course, lack of skill. With the 4 n 1 bucket, I dug a compost pit into the side of a hill. With the teeth, the bucket really digs, and after a while, I could shape the cuts almost the way I wanted them. I couldn't get the hang of scraping with the bucket open, but maybe next time.
The most satisfying experiment was with a dump trailer hooked to the ball in the receiver in the quick attach. I posted a report on the Bri Mar trailer I got in the thread on hydraulic dump trailers in the construction equipment area. With the PT pushing the trailer backward, I could go at a reasonable pace, and position the trailer very easily. I could then nearly empty it without using the trailer hydraulics, since I was dumping downhill. When I did raise the trailer bed, I could shake the tongue with the PT joystick, to make sure everything left the trailer.
The dump trailer will be used a lot behind a truck and behind a Kubota B7100. If it were just going to be used with the Power Trac, it wouldn't have to have a dump bed.
What I hauled today was horse manure and sawdust compost. Before moving it, I beat it nearly to powder with the hydraulic tiller.We are in a drought, so it wasn't gummy. I am learning to use the tiller, and less often shower myself with dirt or horse manure by lifting it too high with the PTO switch on.
I consider the day a real success because I loaded the brand new trailer three times with the Power Trac bucket, without once bashing the trailer side with the edge of the bucket.
   / Power Trac 1845 Report #2
Charlie,
Thanks for the update. Question, you mentioned you built the compost into the side of a hill. Did you dig a hole that then becomes a compost pile? Is this so you can get a bucket into the pile for turning?
Paul
Paul:
It's really a terrace. I wanted to slow the water flow. I get to it from either side, but dump into it from the top.
   / Power Trac 1845 Report #4
Great idea, thanks. I have a location similar to yours that I have wondered how to make into a compost pile that is easy to turn a well as remove. Dumping from the top will work very well.
Thanks for the great idea.
Paul
   / Power Trac 1845 Report #5
Pushing a trailer is great for maneuvering, ain’t it? I never thought about dumping it with the lift arms. Something so obvious is sometimes so hard to figure out on my own /w3tcompact/icons/laugh.gif.
   / Power Trac 1845 Report #6
If you had a dumping trailor could you not get a hydraulic ram(cylinder) and hook it up like a dumptruck using the quick connect line?
KCook
It would be a piece of cake to do and would work well, I'm sure. The only reason I didn't do that is that other machines will be pulling the trailer, probably more that the PT will.
   / Power Trac 1845 Report #8
<font color=red>Pushing a trailer is great for maneuvering, ain’t it? I never thought about dumping it with the lift arms.</font color=red>
What a concept. Position your trailer. Quick detach it. Quick attach a loader & load the trailer. Drop the loader. Grab the trailer & go dump it. Repeat.
When I was at Power Trac a couple of weeks ago, Sean showed me the first bendup of a trailer they are working on. A push trailer with a quick attach plate and a dump gate - just lift and dump. I think they see it as a landscapers tool for moving soil, mulch etc. The bed is roughly 3-1/2 ft wide and 6 ft long as I recall. The sides come up straight maybe 18 inches then flare at about a 45 degree angle out over the wheels. The flare is intended to make shovel access to the load easier. Sean says they hope to have it available around June or so.
   / Power Trac 1845 Report #9
Cool, any other new idea's from Power Trac?
KCook
   / Power Trac 1845 Report #10
I guess the only hard part would be balancing the trailer while loading it, unless it is a dual axle trailer?
2021 Ram ProMaster 2500 Cargo Van (A44571)
2021 Ram ProMaster...
John Deere 24ft Harrow Drag (A47484)
John Deere 24ft...
1996 Eager Beaver 50 Ton RGN Lowboy Trailer (A45336)
1996 Eager Beaver...
2025 Wolverine DB-15-84W Skid Steer Dozer Blade (A47484)
2025 Wolverine...
APEX Ag Equipment Hyperdisc H18/20 | High-Performance Tillage Disc for Precision Farming (A46878)
APEX Ag Equipment...
2020 Nissan Rogue SUV (A44572)
2020 Nissan Rogue...
