Power-Trac 421.667 upgrade questions
   / Power-Trac 421.667 upgrade questions #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
So I got some help from the forum on identifying an older pt. Compelling answers were given for it being a 418, 422, & 425. So I averaged them and will call it a pt421.667. Which is accurate enough since it's getting a predator 670 honda gx clone engine.
I'm now asking for help upgrading it some...
I'm replacing the hydraulic valve since one spool was seized, and adding a two spool valve to enable hydraulic qa and grapple on their own. I've ordered another hyd qa plate from the mother ship.
The pto is a manual handle, aimed squarely at my shin and loose enough to move on its own. To upgrade, I'd like to duplicate the switch/solenoid setup from my more modern 425. I have two questions about that :
1- can someone please link the right valve at surpluscenter.com?
2- what kind of plumbing would I need to add to let a pto attached motor/tool spin down (motor wind down) as opposed to sudden stop.
2b- would the plumbing recommended above offer some stall protection when a tool locks (EX rock in tiller, fence in brush cutter, impatience in stump grinder)
Thanks gang... Any other modernization I should do while I'm in this thing? Bluetooth tachometer is obvious.... So what else?
1267 (A50490)
1267 (A50490)
2018 Ford F-150 4WD Pickup Truck (A50860)
2018 Ford F-150...
2018 John Deere 8370R Tractor (A50490)
2018 John Deere...
2008 HINO 268 ARMORED TRUCK (A50505)
2008 HINO 268...
RYOBI 3300PSI 2.4GPM GAS PRESSURE WASHER (A50460)
RYOBI 3300PSI...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
