Snow Power-Trac Snowblade
   / Power-Trac Snowblade #1
Skalini
Depere, WI
Power Trac PT422
I tried out my snowblade for the first time and I am confused to the design. I have a crushed granite driveway at my cottage and this blade is a struggle. I understand stone always is difficult but this design is unusual. I just don't know why they have the wheel kit? Why not just a blade with springs and skid plates like every other snowplow out there.
   / Power-Trac Snowblade #2
i was thinking of making a set of wheels for mine for the first snows of the season, as im on gravel also. are you saying that the wheels dont work???
i thought that wheels make it work easier on grvel. Mine has simple hardened shoes and actually only removed a very minor amount of gravel....very minor considering how much road i had to do.
you have any pics???
   / Power-Trac Snowblade #3
wheels should work well but I do not know their setup. The vertical angle of the blade is everything when the gravel is not frozen. Angled wrong, it will dig into the gravel.
Ken
   / Power-Trac Snowblade #4
I like my wheels on my power angle snow blade for our PT425. You have to play with the angle left/right AND the angle of the dump/curl AND set the spacers on the wheel height to what works best for you.
I have found that if you keep the blade pefectly perpendicular to the surface you are plowing you can angle it full side to side and never get one corner to raise or dig in. If you dump/curl the blade forward or backwards from perpendicular, you will start having problems gouging one corner or the other.
So, for setup, I recommend setting the blade straight forward, then setting the dump/curl to make the blade perpendicular to the ground. Then lift it up and adjust the wheel spacers to get you the amount of clearance you want. I keep mine about an inch off the ground for the gravel areas. Once you set that, you should be good for the season. You just have to remember to return the blade to perpendicular if you change the dump/curl angle during operations. Once you get used to that, you should be good to go. :thumbsup:
   / Power-Trac Snowblade #5
BTW, skids are terrible when the driveways are soft - they dig in. Once the driveway freezes, life is good.
Ken
   / Power-Trac Snowblade #6
On my 1460 the rubber lip works really well with the gravel. Things are more difficult when the ground is soft, though.
Thanks for the feedback. 100% operator error. I used the blade again this weekend and it worked perfect. I have had this 422 for two years and I am embarrased to say I didn't know it had float capabilities. Using the float with this blade works real well.
   / Power-Trac Snowblade #8
:laughing:
Don't be embarrassed. Any day I don't learn something new is a disappointing day. :thumbsup:
I have been using the blade several times this winter and it works excellent.
   / Power-Trac Snowblade #10
My snow blade is 10 years old now and showing signs of abuse. Both bottom corners are starting to bend back. The support for the left wheel is starting to twist, which makes it difficult to get the blad flat on the ground from left angle to right angle. Time for some repairs this summer. I'll have to straighten the wheel mount. Then I'll have to straighten the corners and add a cutting edge for support. That should do it.
I'll have to say that I purchased it for I think $450 10 years ago. So, $45 bucks a year for snow removal is not a bad deal at all. :laughing: I'm sure with the repairs and beefing up I'll get many more years of service out of it for probably under a hundred bucks. :thumbsup:
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
