power washer....no water
   / power washer....no water #11
When you are running a line like this how deep do you go to keep the water line from freezing, your frost depth?
Consult with a local plumber. Codes vary. You always want it at least as deep as your frost line, plus a safety margin. Code may have a different idea of what is required, and the inspector (if it is ever inspected) may have a different idea still. Here is what a neighbor of mine, who is a plumber, said when I asked him a similar question:
Most local building authorities require 18" depth on water lines. However, if you look at the charts in the building code books the frost line for this area is about 11", but the minimum frost line requirement for any location is 12". However, a 6" buffer or margin of safety is usually required, thus ending up at 18" here. When I was a plumbing inspector for the City of Knoxville there was always lots of discussion on this matter and most times it was somewhat discretionary on the part of the inspector when rocky ground or other problems arose. I can tell you from experience that I hardly ever see an underground water line freeze around here anymore, and we've seen quite a few that are as shallow as 10"-12". Personally, we try to always install a new water line at 15"-18" and that is the depth I would use on my own line as well.
thanks for all the input....my water system at the cabin is from a natural spring about 1/4 mile from the cabin. I use a hydraulic ram pump to pump to the cabin....this add to the complexity. The electric is not close. I dont have it at the cabin either. I am about 1/4 to 1/3 mile from an electric pole....they would have to add 2 maybe 3 poles to get to the cabin and the same amount to get to the pole barn. probably around $15k to get electric to the cabin and about the same for the pole barn...plus plus.
I thought certain higher end powerwashers would suck from the tank?
great idea on the water from the roof. I just built the pole barn and may research using rain water come spring...thanks for all the input...new forks are aroung $600-800 just to be used for transporting the unit. I also found that a stand alone unit is much more expensive than going the tank and trailer route...you can find a trailer for a couple hundered of bucks plus the same for a tank plus a good power washer.....about $1500 vs minimum of $3500 for a stand alone....
great idea with the shurflo and deep cycle battery.....btw great cottage in Hawaii...wow....very nice!
Been there, done that :)
When we started building our house in 2005, it very soon became apparent that having water would be really handy. Mixing concrete, paint cleanup, etc. We soon acquired a 125 gallon poly tank. I fitted it to a pallet so I could lift it in and out of my pickup with my forks. I later added one of those 12vdc, on demand type, shurflo pumps, 2.8 GPM I think, mounted to a box containing a 12 volt deepcycyle battery. Vast improvement over gravity flow. Really handy once the plumber got to the point I split off the hose and we had one flushing toilet. Refilling the tank was a chore, loading it, going to the fill point, the slow filling, trip back, unloading, reconnect. Once I had roof I established a gutter connection and rain get it filled except if very high use.
One of those high use was in fact a pressure washer, gas powered of course. The GPM was a tad behind so I couldn't do a constant spray, but it was easy enough to learn to time my bursts. It really worked great. Wouldn't hesitate todo again.
Best of luck.
David Sent from my iPad using TractorByNet
   / power washer....no water #14
Use rain water from pole barn roof and get a power washer pump to hookup to you tractor's PTO. And you are set to go, no hassle at all of extra engine etc.
   / power washer....no water #15
Most pressure washer pumps are fine with a "flooded inlet", meaning they will not pull water any distance or from a lower tank, but they also require no pressure at the inlet, so elevating the tank a couple feet and using a 3/4 garden hose (short as feasible) will be all you need.
Ray
   / power washer....no water #16
If you have a pull behind trailer, mount the water tank on it. You could pull it with tractor or pickup to fill it then pull it back to barn connect pressure washer and let gravity feed the water. We have one mounted like this with the pressure washer and hot water burner mounted on a dual axle trailer. Pull it anywhere the tractors are.
   / power washer....no water #17
I have 3/4 poly burried around our property to run water lines to different parts (garden, orchard, barn etc) but I have it hooked up to the outside and when it gets cold i just use the air compressor to blow the water out of the lines. It lets me use the water all summer long, in winter I just carry the water to the chickens. Thanks for the info I appreciate it.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
Nissan Forklift (A55973)
Nissan Forklift...
John Deere 60 Tractor (A59814)
John Deere 60...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56438)
2017 John Deere...
