Sickle Bar Powered sickle bar
   / Powered sickle bar #1
looch
Veteran Member
QC, Canada
CK2620 SE Cab
This was in my local paper last week. The article is in French, but the details are:
- gas powered
- can be attached to an ATV or lawn tractor
- replaceable/extendable cutter blade
- 42" swath
I had a chance to see it at the Huntingdon fair - looks neat. He's only made one and estimates the selling price to be 3200$ CDN (that's way too expensive, in my opinion - maybe the price will be re-evaluated once it actually hits the market).
I thought it would be of interest to those looking for a large edge trimmer, or even something to cut small amounts of hay.
   / Powered sickle bar #2
To cut small amounts of hay you could get a used disc mower for about half that. Sure it may needs some work, but you could buy and rebuilt it for that cost and then have a 8' mower.
Good idea but way to pricey.
Fred
I agree, assuming you have a tractor with a 3ph and PTO.
   / Powered sickle bar #4
<font color="blue"> To cut small amounts of hay you could get a used disc mower for about half that. </font>
Fred, You are right on target--We have about 30 used 6-7 sickle mowers that we have rebuilt in our shio that are for cat 1 three point hitch starting at $395 for pitman type up to $995 for a 7 ft NH belt drive machine--Ken Sweet
Sweet Farm Equipment Co. *Low Cost shipping to most states*
   / Powered sickle bar #5
Ken,
What has been your expereince with the reliabiliy of used disc mowers versus used sickle mowers?
Fred
   / Powered sickle bar #6
Forget used disc mowers !!---Only exception would be a purchase from a estate, If the mower was less that 2-3 years old was was working fine when the gentleman quit using it. Purchasing used from a dealer would only work if you could get a 30 day warranty and then run the heck out of it and see if it will hold together--Note: In any event, never pay more than 1/4 the cost of new for a used disc mower--Ken Sweet
Sweet Farm Equipment Co *Hay Equipment Specialists*
   / Powered sickle bar #7
Ken,
That was my thought as well. A lot of the used disc mowers appear to have been traded in for a reason. These things run at such high speed and are fairly complicated.
I suppose if you are very mehanically inclined and could get a deal on one it could be worth it. But you would probably need to plan on buying parts for it. I have seen 7-9' used ones for 1-2K.
It seems that the sickle mowers are less complex, and since they operate at much lower speeds more likely to last a while even when purchased used.
For ocasional use a sickle would be fine, but for large amounts of hay the higher speed of a disc sure is nice.
Fred
Club Car Utility Cart (A55851)
Club Car Utility...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 CATERPILLAR 349FL EXCAVATOR (A60429)
2016 CATERPILLAR...
60" HANG-ON WHEEL LOADER FORKS (A60429)
60" HANG-ON WHEEL...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
