Powering electric brakes on a trailer when using a tractor
   / Powering electric brakes on a trailer when using a tractor #11
RobS said:
I'm not absolutely sure what leads the controller will need to operate properly. You could always hook it up and test it with a voltmeter on the output side. Maybe someone else can chime in with more expertise.
Here's a generic.
1) Hot from battery
2) Ground from battery
3) Hot from brake switch
4) Hot from controller to trailer brakes (actuated)
The problem with tractors is that there is no brake switch (unless yours has brakelights). Therefore, you can not add a lead from the hot side of the brake switch to tell the controller when to activate (if connected to battery, brakes will always be activated to some degree).
If ya'll need wiring digrams for the plug connectors, let me know.
  • Tekonsha Primus Wiring[1].pdf
   / Powering electric brakes on a trailer when using a tractor #12
Once when I was poor, wired a high current momentary push button switch, which I pulsed, to apply the trailer brakes. Its certainly not as good as a controller. But, it is effective, and cheap.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
1999 Landoll Semi Trailer (A54865)
1999 Landoll Semi...
2015 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52706)
2015 CATERPILLAR...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A54865)
2000 Isuzu NPR-HD...
