Powermaster 3pt leaking down
   / Powermaster 3pt leaking down
Not yet - got the kit on order - should arrive this coming week. I also orderd a shop manual for help. You saw the picture with the remote hydraulic control - I assume all of this is under that. Do you think it comes off as one piece or sections or each piece by itself...
   / Powermaster 3pt leaking down #22
the hyd valve comes off the top cover. there are 4 bolts. all 4 moust come out to rmeov ethe valve.. 2 come out and hte cover will come off the tractor with the valve semi attached... but best to pull it to replace the orings under it
Still waiting for the Hyd parts but the fuel petcock seems to be solved with a new o-ring installed. The one that came out looked flat - I replaced it with a standard round one and snugged it up tight - seems to be good now.... Thanks.
   / Powermaster 3pt leaking down #24
yep, they flatten out with age.
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
Miscellaneous Kitchen Equipment (A53117)
Miscellaneous...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
