Powerservice additive
   / Powerservice additive #11
I don't know about the rest of you but I don't add Power Service to increase my HP, I add it so that my diesel fuel will still flow in the dead of winter. I don't know what is in the diesel when I buy it and I don't want to take that chance. I really don't want to find out when it's too late or too cold that my New Holland wants to sleep in till the weather warms up. /forums/images/graemlins/mad.gif
I drop 96 ounces of Power Service in the storage tank before the delivery-man adds 275 gallons of off-road diesel. I know it's a bit of overkill but it can't hurt. I look at Power Service as cheap insurance, don't know if I really need it but I do know that I really want it. /forums/images/graemlins/grin.gif
   / Powerservice additive #12
I feel confident that you could "waste" your money on worse things. /forums/images/graemlins/smirk.gif
   / Powerservice additive #13
Does a 275 gallon tank really hold exactly 275 gallons? I have wondered about this for years. Most tanks are approximately sized and rounded up or down to fit the closes even number that sounds correct.
   / Powerservice additive #14
Junk,
</font><font color="blue" class="small">( Does a 275 gallon tank really hold exactly 275 gallons? I have wondered about this for years. Most tanks are approximately sized and rounded up or down to fit the closes even number that sounds correct )</font>
This is a interesting statement. I see many tanks labeled similar to this.
CAPACITY 375 GAL
WORKING CAPACITY 356 GAL
I guess if you apply a 5% safety factor you never find out that the tank will not hold the max capacity.
My way of thinking is that a 375 gal tank should hold 375 plus some percentage for thermal expansion. Which is the reason for the reduced working capacity in the first place.
I used to see examples of this when I worked on cars. people would fill their gas tanks to the top of the neck on a hot day and park the car. Gas in underground storage is cooler. So when It warns up it expands, and on newer cars with a sealed fuel system and evap purge the charcoal canister gets loaded with fuel. When the car is started and the evap purge solenoid opens the problems start.
   / Powerservice additive #15
I have noticed that the more hours you have on a tractor, the better it works.
Recently helped a neighbor adjust valves on his tractor at 2600 hours, smoked a little under power. Changed out fuel, cleaned tank and new filters but did not make a difference.
Refilled fuel tank 2 days later with the Powerservice mix and there was a big difference - smoke all but gone, runs a little quieter and he says he gets better performance and run time hours now.
I use it in everything I own (diesel).
Mark
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
1839 (A51248)
1839 (A51248)
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
