Keep in mind that these forecasts are generated by massive computer models that are solving the equations of motion for the entire atmosphere, run ahead in time several days. These equations are what are known in the biz as "non-linear partial differential equations". What does this mean? It means that any error or small deviation in the initial conditions will lead to a large divergence in the model's forecast solution. So in a way,there is a real limitation in how accurate and how far out in time any forecast will ever be. The inaccuracy is not the fault of the forecaster, but is more a function of trying to mathematically predict an inherently chaotic system.
Not quite again. The models, both in physical and statistical output is only guidance. We regularly depart when the guidance doesn't quite have things right. The guidance can only tell so much, with the rest being a lot of research and experience. True on the guidance likely deviating the farther out in time it goes. One of the tricks used is to run the same model equations with slightly different starting conditions. Take all the solutions, average them together, and one gets a better forecast, sort of like everyone chiming in on their best way to fix a problem, which I see so much (thankfully) on this site. Plus there is a LOT of sharing of meteorological data/guidance amongst countries (wish politics was this way
On a side note, for those in the deep freeze up north. The chile pepper folks in India have come up with a pepper even hotter than the red savina habenaro. Don't have the Chile Pepper Mag issue in front of me for the name, but this variety came in with a heat rating of near 1,000,000 units on the Scoville Scale. Probably a result of global warming, (or another cause ;-) ).
Steve
