Preheat light
/ Preheat light #1
rob64
Fruitvale
Kabota 4200
My glow plug light keeps coming on and off once the tractor is running any suggestions
/ Preheat light #2
Does it come on even after the engine is warmed up ?? or for a period of time after a cold start ??
/ Preheat light
Yes it comes on even after the engine is warm. It will come on for maybe 30 seconds then off for a few minutes, back and forth.
/ Preheat light #4
That's worrisome.
Could be the ignition switch is sticking keeping the glow on.
Quick, simple cheap 'maybe' solution is to squirt WD40 into the key slot.
That will liquify and dry lubes that may be causing your problem. Nothing to loose.
/ Preheat light #5
:welcome:
To the forum from Alabama.
/ Preheat light #6
Those 4200 glow plugs are turned on when the ignition is turned to the run position,
then a timer relay under the dash takes over, like Piloon said, your switch may be re-cycling the relay,
or it could be the relay itself or a wiring issue.
Caterpillar Standard Job Description Manuals (A63117)
Caterpillar...
1996 Ford E-450 Shuttle Bus (A61573)
1996 Ford E-450...
PENDING SELLER CONFIRMATIONS (A59912)
PENDING SELLER...
Caterpillar 950B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950B...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
