Beltzington
Platinum Member
This is concerns residential water supply but I believe it qualifies as a Hydraulic question.
I want to T my main water supply line with one side going to the house and the other to irrigate the yard. The house side will be pressure regulated at 60psi, the yard side will not and line pressure often exceeds 100psi. Also the yard will be mostly 3/4" pipe and typically is running wide open when watering.
My question is with the yard side with more flow and higher pressure create a vacuum on the house side that could possible suck water out of the house if say a toilet was flushed when irrigating.
I am placing a check valve on the yard side to prevent contaminants from the potable water but was not planning on using one on the house side.
Appreciate your thoughts.
