Pressure switch/Well water question
   / Pressure switch/Well water question #11
From what I understand the bladder pressure should be 2-3 lbs. below the cut-in (pump on) pressure of the switch - not cut-out (pump off) pressure.
Yes, try 27 lbs. pressure and keep in mind you are using two different measuring devices (pressure gauge and tire tester possibly) so don't dwell too much on getting that pressure exact.
And as you mentioned, clean, inspect or replace the 1/4" pipe the switch mounts to.
   / Pressure switch/Well water question #12
If you have a long stand off for the pressure switch, there could be air trapped in the pipe which will cause erratic operation of the switch. If this is the case you should install a bleed under the switch base.
   / Pressure switch/Well water question #13
Two others have already mentioned it.....set the empty tank pressure at 2-3 psi below the "on" pressure of the switch.
   / Pressure switch/Well water question #14
Pump in the flowing creek.
Check the check valve for debris. Also check for operation on the horizontal.:)
Consider making a cistern alongside the creek for the pump.:)
Of course there are no pinhole leaks in the supply line or at connections??
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
