pressure washer water tank
   / pressure washer water tank #1
wkasr1
S.C/
Kubota B7800
Does anyone know if a pressure washer can be operated if the water supply is from a non-pressurized tank? I have some cleaning to do and there is no water supply anywhere close. Will the force of gravity in the tank be enough to supply the washer's need ? I don't want to ruin my pressure washer but if this water tank will work it sure will save a lot of work.
Thanks in advance, Billy
   / pressure washer water tank #2
Buddy of mine built a trailer with two 55 gal. drums...never asked him how it worked out though...sorry.
I just did a quick Google search for "pressure washer water tank"..I ran across more sources saying you can than can't.Just be mindful that the pump will have to have a certain amount of gpm available.
   / pressure washer water tank #3
I would think as long as there is water in the tank you should be able to use it. Look at all the mobile detailers that have the trailer mounted tank and pressure washer next to each other on the trailer. I would think that as long as the water level is above the pump it should work.
   / pressure washer water tank #4
most pressure washers require a certain gpm , if your tank is big enough, and high enough you should be ok, is there anyway you could SAFELY add some air pressure to your tank
   / pressure washer water tank #5
I had a Builders Square Puma power washer. It came with a suction screen that could be attached to a hose and dropped into the lake to power wash my boats bottom, when I pulled it in the fall. Worked great.
I have one from Home Depot now. When winterizing it with pink antifreeze I stick a short hose from the inlet line. It will suck the bucket dry in a short time. If your washer will do this, then you should be able to use it for washing. Make sure you do not run it out of water. These pumps do not like running dry.
   / pressure washer water tank #6
The short answer is yes it will work, just make sure the hose supplying is water is big enough. Numerous car detailers around here use water tanks with gravity feed to supply water to their pressure washers. Vent the cap and you should be fine.
   / pressure washer water tank #7
Some years back a neighbor who owned City Window Cleaning Company next to our heating business picked up a contract to pressure wash phone booths. Hey does anyone remember those puppies?
Anyway he wanted to know if I could help. So we took one of his empty vans and proceeded to install several large poly-water-tanks inside it that would feed his gasoline power washer so he could do his mobile cleaning thing. It worked so well for him that he started adding more trucks and more equipment for expansion.
Needless to say he wasn't real happy when the phone companies phased the phone booth out of existence altogether.
But feeding a pressure washer with a gravity feed water tank can work successfully.
Thanks to all who replied. Looks like the "yes" have it. My local farm store sell plastic tanks around $1.00 a gal size. Maybe a vertical tank would work best? I think I'll find out. Thanks again.
   / pressure washer water tank #9
I use two 55 gallon barrels, old pickle barrels, to provide water to my pressure washer to clean the bulldozer. I bought fittings to allow a hose bib to be attached to the top of the barrel and mounted a tire style valve stem with the core removed to allow ventilation during both filling and emptying. The barrels lay on their side in the truck bed between the wheel wells and don't move once filled. I use a cheap garden hose to connect one barrel at a time to a gas 2.5 gpm pressure washer. I park the truck up on a hill and feed the pressure washer near the dozer but really only about 8 feet of fall. I must remove the inlet screen from the pressure washer to allow enough flow or the pump loses prime. I also must prime the pump without the engine running and let water fill the system. Once it is going, it works just as though you have a pressurized supply.
The barrels are cheap in most places, the plumbing parts cost more than the barrels. I recommend you use barrels like this. A 2.5 gpm suck on a 55 gallon barrel lasts a pretty long time.
It is tough to move the barrels when they are even partially full so plan on emptying them while in the truck. You don't want to drive around with a partially full tank either since the sloshing may have effects on the vehicle.
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2012 Ram 3500 4x4 Dump Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500 4x4...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
