_RaT_
Super Member
- Joined
- Apr 19, 2000
- Messages
- 5,813
- Location
- Peoples Republic of Northern CA.
- Tractor
- Kioti 3510-SE HST
Electric pressure washers, the commercial type are getting popular. A Landa 5 HP electric easily handles 2000 PSI at 4 GPM. That 4 GPM is significant. My opionion is that give me 4 GPM at 2000 PSI over 2 GPM at 4000 PSI. GFI protection works beautifully. The heavy duty electrics are very quiet, very dependable, some shut off at pressure and as safe as most anything electric will be especially considering the enviroment. A 30 amp or 40 amp 2 pole breaker with GFI protection will address the safety issues.
While you can manipulate the GPM on a on a pressure washer, you can only do so to a relatively small amount. If you remove the tip, run the washer into a 5 gallon bucket and time it to full capacity, you will find what your pumps maximum GPM is. That will be it at almost 0 PSI. By changing tip sizes, you can increase GPM, slightly, but that will also affect PSI. My suggestion is to purchase as much GPM as you can afford, pressure is second to the GPM. Identical pumps and engines can be set up with different GPM's and pressures by varying pump dispalcement, that is why you need to carefully consider the model and realize making up for GPM via the unloader while seemingly a simple fix, is not that simple. Test for your self using a 5 gallon bucket, a tee at the tip and a pressure gauge, it will be the best way for you to actually determine what your actually getting versus what you think your getting.
