SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,505
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
On a flat surface, take a piece of plywood, lay it with one edge just a little behind the rear tire ground contacts and lift the other edge til the plywood touches both tires and the drawbar end. Measure the angle wrt the surface. This is the tip angle at which the drive force causing a tip and the load force acting on the end of the fixed drawbar are both acting at ground level. This cancels the tip force. A slow tip will not go further. A fast tip will "coast" higher but at the same time be resisted by load force because the drawbar end will be below ground. A fast tip has a cascading effect because it accelerates the tractor CenterOfMass upward. This acceleration causes greater downforce on the rears, thereby increasing traction. Without wheelslip or engine bog the force geometry says the tip will speed up as you tip - a chain reaction. If your measured angle is 30ー you are pretty darn safe because a tractor takes about 60ー from level before it will fall over backward - the tip has to be so fast it will coast on up an additional 30ー. If its 40ー or more I would worry some and try to lengthen or lower the drawbar until it is below 40ー.All,
I just joined TBN and part of the registration is posting for the first time. This string looked particularly interesting, anyway - what is the moral of the story? What should I know to not kill myself trying to move an object too heavy for my JD 1050? In a previous life, I had bad experiences drawing vectors for a demanding (and obnoxious) instructor - when someone recommends getting out the paper & pencil, I generally look for the door. Is it correct to say that pulling from the front while in reverse is safest?
Jim
larry
