Price Check Price Check on a MX5000
   / Price Check on a MX5000 #1
Ryang
I'm looking to buy a MX5000 with an LB702 FEL and R4 tires and wanted to know if anyone could fill me in on thier thoughts about this tractor and pricing please. I will be purchasing a 7 ft bush hog or woods mower for those 30-35 acrer jobs. I own the L3400 with LA463 FEL and really like the tractor, but I'm starting to do some field mowing part time and need to step up. I have been quoted $23000.00 and want to know if this is a good price in Colorado.
Thanks for your help
Ryan
   / Price Check on a MX5000 #2
Not sure about the price but do you have any idea how long 30-35 acres are going to take you to cut with a 7 foot cutter? My guestimate would be 30 hours or more.
You may want to look at a larger setup and pull type cutter.
I should be able to cover 5 acres in 2 hrs with the type of field mowing I'm going to be doing. It takes me about 3.5 hrs to cut my 5 acres with my 5 ft mowing deck on my L3400 now. A 7ft should cut that down to 2 hrs for 5 acres.
   / Price Check on a MX5000 #4
Wow that is pretty quick. What speed are you running?
   / Price Check on a MX5000 #5
I am sure land terrain and type of grasses factor this speed in too.
-Mike Z.
With my L3400 I'm in 3rd gear in high and I cut about 5 acres in 3.5hrs. With the 7 fy cutter in a 50 hp tractor I should be able to cut in 2 hrs or less with 5 acres.
Ryan
   / Price Check on a MX5000 #7
Ryan,
Using simple math and assuming you will be cutting at the same speed:
5ft/7ft X 3.5 hrs= 2.5hrs
The actual mowing time will be slightly less because there are less passes and so less total overlap mowing.
Quenton
Genie GTH-644 (A50490)
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
LOT LOCATIONS (A51219)
