prince loader valve HC-V-BP22
   / prince loader valve HC-V-BP22 #1
gav64
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
Has anyone used/installed one of these valves, I need to replace my loader valve and saw this on surplus center website.
I would like to add a 3rd function for a snowplow this winter was going to use electric solenoid valve but this looks a whole lot easier.
3 SPOOL 25 GPM JOYSTICK LOADER VALVE W/GRAPPLE
Thanks
Glenn
   / prince loader valve HC-V-BP22 #2
Logically, you want to match the flow rate of your tractor with the loader valve selected.
Mahindra 2810hst
Hydraulics:
Type: open center
Gear Pump flow: 5.88 gpm [22.3 lpm]
Hydro Pump flow: 6.3 gpm [23.8 lpm]
Gear Steering flow: 3.07 gpm [11.6 lpm]
Hydro Steering flow: 4.55 gpm [17.2 lpm]
If your tractor flow rate is about half the loader valve, at half lever, you will be flowing total pump flow.
You could get this loader valve and still get a diverter or a 3rd function valve.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Diverter valve from Baileynet for about $110.
3rd function valve from Surplus solenoid OC valve
12 VDC 10 GPM OC DA SOLENOID VALVE
1 STATION DO3 SUBPLATE OPEN CENTER
Self Dumping Hopper (A53316)
Self Dumping...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 68in Dual...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
Peterbilt 377 Semi-Truck (A55302)
Peterbilt 377...
