Printer is online thru Ethernet Security Issue
   / Printer is online thru Ethernet Security Issue #11
Much thanks;Foxit was the answer worked perfect.I had spent hours and hours trying to find a way to convert PDF files;again thank-you
Glad that solved your problem! The other freebe program that you might find useful is PDF Split & Merge (PDFsam). It allows you to selectively add and remove sections in PDF documents or merge entire PDF files. It's a little tricky to use at first but works great once you figure it out.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
