Problem with hydraulics
/ Problem with hydraulics #11
Tried that last night. Saw what I believe to be the bleeders (attached pic). I loosened the one on the left, started the tractor, saw some little bubbles escape (no real mess), shut her down, tightened, restarted and still nothing.
Repeat, until no bubbles. one side at a time.
OR, pay the dealership to do the same. :confused2:
Should I just let it run with the bleeder open until I get some movement in the hydraulics?
Edit: I let it run this AM for about 5 mins till I noticed the pump was starting to feel warm, then I shut it down. Nothing. Starting to feel nervous now. :(
/ Problem with hydraulics #13
I am not an expert but these systems hold ALOT of fluid. You might need to repeat this several times over while keeping a close eye on the fluid level.
Are you sure you patched/replaced the hose that had the hole in it? This could be leaking air back into the system.
The dealer never called back (after several calls) so I called another outfit who came out the next day. The line that I'd pinched was unserviceable (probably split, though I didn't detect a split when I was feeling around.... which only means I missed it) and was probably leaking air as you suggest. They rigged a temp hose till a new one can be ordered and called to let me know she was running again.
I only worry that I might have screwed my pump with the dry running.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
12' Container w/ Side Door (A60463)
12' Container w/...
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
30ft Highway Trailer Co. Lowboy (A61307)
30ft Highway...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
