problem with paper shredder
   / problem with paper shredder #21
I use a Fellowes paper shredder from Walmart, and I also use Fellowes Performance Oil periodically. I just pour a line of the oil across a sheet of paper, then run that paper through the shredder. I don't think I've ever heard of lube sheets for shredders before.
   / problem with paper shredder #22
They are just smaller than printer paper sheets that have been impregnated with some kind of oil that you run through from time to time. I think your method is most likely better and a lot cheaper.
2025 GPS Trailers (A56857)
2025 GPS Trailers...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2444 (A60432)
2444 (A60432)
