Problem with starting 2014 Hustler Raptor SD
   / Problem with starting 2014 Hustler Raptor SD
I was sitting in the seat with it running when I engaged the levers. Engaging the left one killed it. I'm going to try loosening the screws and bump that left side lever safety switch over a wee bit, and hope that will remedy the problem. Being a widow on a fixed income, hiring a repair guy is my last option. :) Thanks so very much for your input Ford850!
The end verdict...
Well, I had a bad seat switch. The "switch" on the left lever arm was "stuck." I sprayed it down with alcohol and cleaned it with a rag. Replaced the solenoid, I'm in business! Thank you everyone for your responses and input!
Blessings all!
harat547
   / Problem with starting 2014 Hustler Raptor SD #13
That's the most common culprit. Thanks for following up with the solution so it can help others in the future!
2013 Ford Taurus Sedan (A59231)
2013 Ford Taurus...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2018 John Deere TX (A53317)
2018 John Deere TX...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
