wroughtn_harv
Super Member
If the slab has a perimeter beam I'd consider (I'm assuming this is your nickel) doing a pier or three on that corner to preclude further deterioration.
Think of an "A". The two verticals would be twelve inch holes drilled down about ten twelve feet. Instead of a cross line dig a haunch or box at the top of the "A".
This configuration when properly installed makes movement up or down less likely. It's what engineers recommend around here for our clay when the foundations start moving.
In fact you could place a series of these piers around the perimeter along with some by your cross beams and raise the slab. It happens all the time. Clay soil moves.
