problems with fuel in cold weather
   / problems with fuel in cold weather #11
Need is a relative term. A number of folks here are of the opinion that you do not "need" to, and for the most part, the odds are on their side. Just like you do not "need" a spare tire on any given or even most days.
The day that you do need it is the problem. Using it prevents needing it.
   / problems with fuel in cold weather #12
Well said, RFB.
   / problems with fuel in cold weather #13
Thanks, I do carry a spare. I just did not want to add stuff it was already added to the fuel as part of some seasonal adjustment. I presume this stuff is available at major auto parts stores?
Dan
   / problems with fuel in cold weather #14
Better put some Slick 50 in that crankcase, too.
Never know when you might need the extra lubrication.
   / problems with fuel in cold weather #15
Danny,
Power Service products are ubiquitous; I have purchased from WalMart and NAPA auto. The white bottle is the general purpose fuel treatment that reduces pour-point (keeping the paraffin inherent in diesel fuel in solution) to prevent filter and fuel-line clogging. It also adds lubricity to the fuel, which can be slightly reduced in winter fuel composition.
Power Service 9-1-1 is a different product (from the same mfg) that is used after the paraffin crystallization has occurred. It returns the paraffin back into solution, but is not intended for continual use. The white bottle product is for continual (every day).
   / problems with fuel in cold weather #16
DannyLobster said:
If I use on road diesel do I still need to add additives for use in cold wether? I am A newbie and need to make sure I can plow if we ever get snow this year. I am located in Central MA so it does get cold.
Dan
My understanding, Dan, is that off/on road diesel is irrelevant to your problem, and has to do with the tax you pay on the fuel. The off-road diesel is not taxed at as high a rate.. and is dyed a bit reddish so that if someone is using it on the road to avoid the taxes they can be shot or whatever is deemed the appropriate punishment in your locale.
Your issue has to do with the summer/winter blend of the fuel, not the on/off road taxation.
I just keep a 300-gallon tank of off-road diesel behind the garage, and it gets filled with whatever blend the oil company is using at the time of year they happen to stop by to top it off. I always add Power Service when that tank is topped off, and I've yet to have any problems even down to -20 F.
I've spoken to the Power Service people, who reassure me that using a lot more than recommended will not hurt anything but my wallet. So, when in doubt, I just dump in some more. This system has worked fine for 5-6 years now, and it's very convenient to just pull up next to the tank and fill up, rather than making runs to the gas station with smaller cans.
HTH,
Bob
   / problems with fuel in cold weather #17
Dan
Yes.
Bob
   / problems with fuel in cold weather #18
or...
dont cut your fuel at all. keep some addative around and dose as in summer and do what I did.
fabricate a residual exhaust driven heater for the fuel bowl on your massey! I used a 3 or 4 foot section of commercial shop vac hose (steel gooseneck) that fits over the exhaust pipe and travels around the front over the front axle back up under the removable 1/4 panel and made a custome bracket. It redirects the exhaust gasses about 5 inches away from the bottom of the fuel bowl. The beautiful part is you dont have to worry about melting the plastic fuel bowl because as the exhaust gas temp rises (more throttle) the bowl draws in a relative amount of cold fuel from the tank so you exchange the heat at the same relative rate and temp throttle up or throttle down. total cost $45.00 no headaches. pics to come. As an aside, the massey fuel system is the most poorly designed piece of crap I've ever encounterred. Even my 35 year old John Deere of the same hp has a intermediary fuel heating system oem. nuff said.
   / problems with fuel in cold weather #19
PS. Just did this today and it was -12 last night. The heat gun on the fuel bowl trick works if you don't mind having someone walk beside you with a 200+ foot extension cord to and from the spreader, unrealistic. I gt pissed today and built the residual exhaust heater. we use or 1533 and loader to load a larger spreader which we empty once a week. (manure) if the massey doesn't run 365 days a year, regardless of weather, we dont get our chores done and the horses get pissed, literally! Now I have a tractor I can count on everyday of the Year! yay! pucs soon.
   / problems with fuel in cold weather #20
Yeah,change your fuel filter(s) as your paraffin probably dropped out of the fuel(starts dropping out at 15 degrees with straight #2 fuel oil) I run 30% K-1 Kerosene in the winter.I know...Iknow....many people say NO! do NOT mix K-1 into diesel,but I have for years and no problems.Just 30%.....not 40%. IF you can get true #1 fuel oil,you can go to 50% in cold weather.
But consult your manuals because things have changed a lot with newer diesels and I'm talking only about older,larger engines. don-ohio :)^)
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59575)
2021 CHEVROLET LCF...
1408 (A57192)
1408 (A57192)
2016 FREIGHTLINER  CASCADIA TADC (A59575)
2016 FREIGHTLINER...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
