problems with pto my jd 790, 5' rotary cutter mower
   / problems with pto my jd 790, 5' rotary cutter mower #11
The pto grinds when engaging with a load because the clutch is not stopping the pto shafts entirely. Without a load, the shaft jumps right in without grinding due to no weight to spin. If you adjust the three pto bolts to spec through the screen hole, it should work properly. You need to shorten the bolts until the gap between bolt head and clutch plate is .060" which is spec. I like to adjust to about .055" to give a little more wear before it needs adjusting again. Check the gap with a feeler gauge.
Thank you. I adjusted the bolt heads to .055" today and it is the first time in 20years the pto engages smoothly.
   / problems with pto my jd 790, 5' rotary cutter mower #12
That's good news.. :thumbsup:
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
Rogator New Leader RG1100 (A50123)
Rogator New Leader...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
