Progressive finish mower 120
   / Progressive finish mower 120 #1
JasG
CNY
B2650,
Has anyone any experience with Progressive Pro Flex finish mowers?
If yes how good are they and how strong are they built? How easy are they to service?
   / Progressive finish mower 120 #2
Yes I have one and mow 20A with it. It does a great job. If the grass gets high you well eat up belts, you have to keep the grass low and mow often. When the grass is growing fast I use my woods 990 set at 4". The pro flex's max hight is 3" , that I don't like and would use it more if it would go to 4". As far as service it takes more, there are a lot of grease fitting on it. One thing when your done mowing, you can hit that little white ball around with that stick that is bent on the end.
Thanks for the information.
That is what I was thinking seeing the belts drive everything.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2014 COTTRELL CX-09LS2 AUTO HAULER (A56129)
2014 COTTRELL...
2016 Isuzu NRR Trash Truck, VIN # JALE5W162G7300782 (A54865)
2016 Isuzu NRR...
MD ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
MD ELECTRIC GOLF...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
17201 (A55852)
17201 (A55852)
