grsthegreat
Super Star Member
i too live in north idaho...athol idaho to be exact. we have a wood fireplace for backup heat source. The primary heater is an electric heat pump with a gas back up (when outside temp is below 20F). Since our electric prices are only $0.06/KWH, electric heat pump seemed the best way to go. I also have a propane backup generator to assist if all else fails. were on a community well system, so i dont have to worry about powering up a well. It helps that im an electrical contractor, so i pre-wired my house for the backup generator. Alot of people up here do plan on using a generator, and i wire alot of houses with that in mind. Also keep in mind that a large instant hot water heater in the electric model takes alot of energy to run., ive hooked up some that need three (3) 60 AMP CIRCUITS TO OPERATE THEM.
Heat pump systems are not complicated, and work very efficiently down to say...+25 F, then either electric or gas backup kicks in raising the cost. I have a 4200 SF house, new construction, heavy on insulation. Not counting initial start up load, ive tested my heat pump while running and it only draws about 32 amps.....remember, a 2000 watt baseboard heater can draw 15-20 amps, and heat 1 room. im heating the entire house for this.
Now, usually when its super cold outside, im burning wood in the fireplace so it really doesnt matter. One further bonus of the heat pump system.....You get air conditioning for no additional cost of equipment. The equipment simply reverses flow. I do like A/C on some of those hot days in the summer. Now i dont have to leave windows open, and dont get a house full of dirt moving with the air.
My 50 Amp propane backup generator cant power up the heat pump, but my backup heat for the heat pump is propane. So my backup genset powers up the gas furnace, most of the lights, refer, freezer, microwave, master bath, entertainment system, and for some reason....my xmas lights. Im not sure why i did that..probably to piss off the neighbors when power fails and my xmas lights are on .:laughing:
:thumbsup:
