Proper use of a top link adapter
   / Proper use of a top link adapter #1
Fastball
North Okanagan, British Columbia
Kubota L2900
I recently picked up a quick hitch - and of course, one or two of my older implements aren稚 QH friendly. So i have rigged up a floating top link adapter to get them attached. Now I have read that the purpose is to let the implement follow the contours of the ground more closely...like in my mower or rake. However, I have been told NOT to use a floating link on my rear blade for snow removal, etc. I do not understand how this is a different application than a mower or rake.
Can an expert please instruct me in what is a proper use of a floating top link adapter?
Thanks..
   / Proper use of a top link adapter #2
The only floating top link that I know about is just a chain. It runs a bit slack most of the time to allow the implement to follow contours but is short enough to possibly allow a little bit of lift when the 3ph bars are raised.
My 2 bush hogs have had a floating system built into their mechanism. You set the top link to where the floater indicator is at mid point when the bush hog is on a level area and at its proper height. The bottom links have to be such that the top link never is longer than the lift arms. There are usually at least 2 points to place the lift pins to achieve this. Otherwise, the bush hog will be driven into the ground when you lift the unit. I learned this because my 1st bush hog pins were set wrongly.
I'm not sure what finish mowers have as a floating top link system, probably something similar to the bush hogs. Know nothing about a rake.
Ralph
   / Proper use of a top link adapter #3
I have float on the valve for my hydraulic toplink. I always leave it in float when I'm mowing with my frail mower or former rotary cutter.
I use float a lot to level things out when hitching & unhitching. But that's only briefly. I love the hydraulic toplink for grading with the box blade or LPGS, but float really isnt useful for operation of them.
I didnt find float useful when I had a 3pt grader blade. It kind of fought with the fact a 3pt doesnt have downpressure. It would fold up like a taco a lot.
   / Proper use of a top link adapter #4
Never seen or heard of using a floating top link on anything but a mower. I just modified all my other implements to accept the quick hitch hook. I use the adapter on my finish mower. My brush cutter has a slotted top pin hole instead of pivoting linkage. Still working on the best hook up for it. Last time I set the hook in a different hole and just used one pin so it could wobble.
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2015 Chevrolet 3500 Diesel Truck (A50490)
2015 Chevrolet...
2005 Bobcat S185 Skid Steer (A50490)
2005 Bobcat S185...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A50397)
2017 Yale GLC050VX...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
