Pros and Cons of using tracks on a skidsteer
   / Pros and Cons of using tracks on a skidsteer #1
ric
Marengo, Ohio: email videos@bright.net
Kubota 245DT and 175F
Is using tracks on a skidsteer really as big of a problem as I have read that it is? If so, what are the real problems and how do they develop? If tracks are an option, what are the best ones to use and why? I am asking because where I live its wet more than its dry which limits the amount of work I can do with my skidsteer waiting for it to dry out enough to get back to work. I have an 1845C.
Thanks.
   / Pros and Cons of using tracks on a skidsteer #2
Only 2 cons that I can think of:
-mars pavement
-flat tires inside tracks
All kinds of pluses. Because of the cons I bought a rubber track machine.
Seems like the biggest down side to using tracks on a skid steer is premature chain wear and breakage.
Although I have heard it supposedly easier to loose a tire I have not run across anybody who actually had that happen.
I was considering rubber tracks, but they seem to cause the same problems as metal tracks.
   / Pros and Cons of using tracks on a skidsteer #4
From what I noticed on an 863 with tracks, it seemed the engine would lug a bit more than what I thought it should lug without tracks on. It may have been the operator (really trying to kill the engine) or it may have been the tracks... not sure.
   / Pros and Cons of using tracks on a skidsteer #5
Metal tracks or rubber tracks are nice in the wet weather. 3 years ago I called the local Bobcat dealer to demo a T190 tracked machine because my rubber tired machine wouldn't perform in the mud. I considered steel tracks but didn't get them because I run on pavement alot. I really had no intention of buying that machine. Two weeks later I owned one. I still have my 843. Both machines have their advantages.
My concrete guy runs steel tracks on his Deere this time of year and has no complaints. Also a brick mason I know runs steel tracks on a 773. Offroad they perform as well as rubber tracks. In the mud they might even get better traction than the rubber. I do know that steel tracks are hard on the drive motors, but if you only have one operator on the machine and not a bunch of cowboys, you should be alright.
   / Pros and Cons of using tracks on a skidsteer #6
I don't know how you think steel tracks preform better in mud than rubber tracks. If you are in mud and need traction, you need a dedicated rubber track loader. Look at Cat or ASV. They perform better than any other loader. They both use a suspended undercarriage. Great track life and excellent flotation. ASVI.com is where I found a dealer by zip code.
   / Pros and Cons of using tracks on a skidsteer #7
Yes - but the operating costs for track machines are WAY higher than for tires.
For those of you who get Compact Equipment mag www.compactequip.com - there is a great article in the June edition that talks to the pros and cons of tracked skid-steer machines and reviews several models.
General consensus is - if it's dry - use tires, if it's too wet, tracks are better.
Someone just came up with a new solution - a bolt-on undercarriage that replaces the existing wheels. Just jack up the machine, unbolt the wheels, bolt the undercarriage to the hubs, and voila = tracked machine. I don't have a link - maybe someone else does
   / Pros and Cons of using tracks on a skidsteer #8
Well, I read all six of your today's posts promoting ASV products and badmouthing the competition and was wondering if you work for the company or are you just a stockholder?
   / Pros and Cons of using tracks on a skidsteer #9
Yea, I see what you mean jmc... Any explaination?
   / Pros and Cons of using tracks on a skidsteer #10
He's either an overenthusiastic supporter of a couple of ASV's talking points or this is a clumsy marketing attempt. I doubt if ASV corporate supports such an effort though, as they seem knowledgeable and professional. Then again, maybe he's trying to make ASV look bad?
One interesting thing is 14 minutes after registering, he's saying he traded his other brand tracked loader for an ASV. Then a few minutes after that, on another thread, he's masquerading as a potential buyer, asking leading questions.
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
Spreader Attachment (A56859)
Spreader...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
