Pros/cons pull type v. 3 pt mowers
   / Pros/cons pull type v. 3 pt mowers
There are several that make 7' mounted rigs..........and for less than $6500.
7' M.H.D. CUTTER W/2 WHEELS W/CH [MH72TC] - $3,023.00 : Howse Implement Company, Your source for tractor and farm equipment parts and supplies
Heavy Duty Rotary Cutters
And if you're not absolutely set on a twin-spindle rig there a scad of others out there that will sell you a 7' cutter for less.........Kodiak, Mohawk, Taylor-Pittsburgh, Modern Mfg, King Kutter, Big Bee, etc.
There are a lot, but I don't think any of them off hydraulic height adjust. I need that feature. Woods is the only one I can find that has hyd height adjust.
   / Pros/cons pull type v. 3 pt mowers #12
You can raise pull type bush hogs I dont know what any of you have been around but Ive been around plenty of pull types that lift with a standard 3 x 8 cylinder. Woods and other companies make these.
Given my choice, I'd like a 3pt, 7-foot, twin spindle, hydraulic raise/lower rotary brush mower for ~$2,000. It will probably a used unit, as long as it is in good shape.
   / Pros/cons pull type v. 3 pt mowers #14
Check out Kodiak Manufacturing Mowers KODIAK MFG., Inc. I just bought their 10' Pull Type from our Mahindra Dealer for $4,600 including hydrualic lines and cylinder.:eek:
2015 Ford Transit 250 Cargo Van (A53422)
2015 Ford Transit...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
