Proud New Owner of a BX23
   / Proud New Owner of a BX23 #11
Welcome to the BX23 Klub!
2. I ... would like to hear what the available Tillers are that are compatible/recommended (so far the Woods GTC40 seems the right buy).
How wide is the Woods tiller? (Sounds like maybe 40"???) With 80 hours of time on my BX23 so far, I am pretty well convinced that there is no need to go with anything (BB, RC, tiller, etc.) narrower than the tractor (48").
3. Sometimes ... there seems to be excess pressure in the lines ....
Yes, look through the procedure in the Operator's Manual again. IIRC, it says to cycle all of the control levers to all positions after shutting off the engine but before disconnecting hoses. That will relieve pressure.
4. ...the hydraulic lines felt very hot ...?
Yes, normal. Hydraulic fluid = transmission fluid, which is being pumped around quite a bit. One of the easiest ways to heat a fluid is to pump it through a restriction.
Enjoy!
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2006 FREIGHTLINER CST120 (A53843)
2006 FREIGHTLINER...
