schmism
Super Member
no advise on useing a driveway scraper, but i do own a rear blade and maintained 400' of drive that grew green stuff in the center. I kept mine crowned well as i had deep ditches on either side of mine (my drive sat about 1' above the surrounding ground). I used a HD rear blade and found it easy to maintain. I usually ran a heavy pass right down the middle cutting off 2" and pushing the material to both sides (straight cut) This means i bunch up a lot of dirt/sod/grass/gravel at the end of the run. id make 2 passes down and back across the middle and spread out the chunky material at the end of my drive were i needed it. Then a pass down the right and left side dragging material back to the middle and wind rowing it, then a finnal pass down the middle to smooth out the windrow.
in a couple of weeks when the chunky grass died off and the dirt was washed out, id often re-grade that area to reclaim the gravel.
i could cut the above steps in half if i sprayed first and waited for the grass to die off.
