PT-425 PROS & cons??
   / PT-425 PROS & cons?? #181
Re: PT-425 PROS & cons??
>>>> after reviewing the last few months of postings, I don't see much new - mostly questions which have been already answered, some extensively, before!! <<<<
Ahh common, you love talking about your reversed wheels. /forums/images/graemlins/smirk.gif
   / PT-425 PROS & cons?? #182
If Fourteen ever broke a wheel motor I don't think he would tell us.
It just seems to me that if reversing the wheels is the best way to go , they would come from the factory that way. and they would place a warning placard that moving the wheels in closer will give a thousand more hours of useful life.
Do you all think that if you moved those wheel out another foot that it would be even better.
I am all for safety and stability. Just do what you got to do.
   / PT-425 PROS & cons?? #183
   / PT-425 PROS & cons?? #184
JJ,
People have been adding weight and making wider tractor wheel spacing likely as long as there have been tractors....
Adding 900-1000 pounds of weight to the back of a traditional CUT to offset the loader also puts additional stress on wheel/axle bearings, differentials, transmissions, brakes, etc -- but people have been doing it for decades. Hanging a backhoe off the back or FEL off the front has similar effects, all by themselves. Similarly, spreading the wheels farther apart also increases the stress. But, the manufacturers have even facilitated making the wheels farther apart, by offering wheels that "spin out" and lock down in new locations...
If every tractor, vehicle or machine left the factory in the "optimum" configuration for each individuals' needs, there would be no need for an aftermarket, nor any need for all the modifications that owners perform to them.... /forums/images/graemlins/laugh.gif
IMO, the PT factory does what it does:
(1) to minimize the costs of warranty claims and repairs... and,
(2) to give satisfactory service with the existing size of attachments rated for these machines -- for example, if you reverse the wheels they're now wider than the buckets for the T-8 machines, the 48" brush cutter, 48" finish mower, etc.
I may put my wheels back in the stock configuration at some point, but for now I'm taking full advantage of having the wider stance... if my wheel motors get damaged, I'll deal with them then, and likely replace them with higher torque/lower speed versions at the same time....
BTW, <font color="red"> Fourteen </font> , it's great to have you back posting again -- you were missed! Hope your new "bionics" have solved any health issues... /forums/images/graemlins/grin.gif
   / PT-425 PROS & cons?? #185
JJ,
   / PT-425 PROS & cons?? #186
Hi FOURTEEN,
It's great to see you back on the Forum. Best wishes to you and the Mrs.
I have likewise not experienced any difficulties with the reversed wheel configuration. I measured the "track" before I switched (outside tire contact edge on one side to outside contact edge on the opposite side, with bar tires) and it was 46". After the switch, it increased to 52" as a result of inverting from a positive wheel offset to a negative wheel offset by 3" per wheel.
While a 6" track widening is not a huge change, I really appreciate it on hills, and in the woods especially. I've also eliminated the grass choke between the left front tire and the tub when mowing. I can see where wheel reversal would pose a problem for the 48" mower in trying to get close to edges and such, but not for any other implements that I have used.
I would hazard a guess that there might be more "closet wheel reversers" out there, and that as members of a wonderful, collegial group, we would share the negative as well as the positive. Next thing you know, we might hear from Charlie Iliff telling us that HE reversed his wheels! /forums/images/graemlins/grin.gif
   / PT-425 PROS & cons?? #187
Hi FOURTEEN,
   / PT-425 PROS & cons?? #188
I'd reverse mine immediately if it would still fit in the back of my pickup. That's the only "down" side that I see.
Phil
   / PT-425 PROS & cons?? #189
Phil
   / PT-425 PROS & cons?? #190
I'm sticking with J_J on this one... do what you want with the machine, it is yours to use as you see fit... however, be prepared to repair it when it breaks from using it for things it was not designed to be used for.
That is the beauty of the PT design. Slap some more steel on it, modifiy it to your heart's content, play with it and get it to be the machine you want it to be. Just don't whine when you break it. Document the failure, share the experience, get made fun of a bit(good natured, of course), rethink your design or application, rework it and try again.
I really think the lot of us PT owners have some crazed scientist bottled up inside. That's why we all enjoy these machines and experimenting on them so much. Igor, pass the wrenches!!!! /forums/images/graemlins/tongue.gif
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
FORREST RIVER CHEROKEE CAMPER (A55745)
FORREST RIVER...
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
