PT-425 PROS & cons??
   / PT-425 PROS & cons??
Re: PT-425 PROS & cons??
Did you get the 2"OD Sleeve?? Any further problems?? /forums/images/graemlins/confused.gif
   / PT-425 PROS & cons?? #132
I didn't measure it but I will. I've had no more problems but I've not done as much with it since then. I did dig a 2-1/2 ft deep 20 ft long trench through rock and clay today without problems. I had done alot of lifting stumps, burning brush, moving logs around as well as alot of digging with it prior to it breaking. That was October I think, and it's done great since.db
</font><font color="blue" class="small">(
Any further problems?? /forums/images/graemlins/confused.gif )</font>
The comments in this thread refer primarily to my PT-425 built in February 2004 with the Kohler engine.
However, many are also applicable to newer versions. The best tire pressures for the PT-425, for example, are still 7# rear and 11# front!
   / PT-425 PROS & cons?? #134
How many feet above sea level? /forums/images/graemlins/grin.gif
   / PT-425 PROS & cons?? #136
Ha ha ha ha ha... Good morning, Fourteen! /forums/images/graemlins/laugh.gif
For cheap, effective, neat looking PTO Hydraulic Coupling Covers, it is hard to beat Zip-Lock Snack Bags (6.5" x 3.25")!!
Cut off one short side. Slide the bag over the coupling and onto the round bracket with the zipper facing down. A little oil on the bracket inside the bag will hold the bag in place, make a dirt and water resistant seal, and make the bag nearly invisible!! If you lose one, so what, they only cost pennies a piece!!
If you are on a really tight budget, cut each bag in half crosswise and make two bags out of one!!
   / PT-425 PROS & cons?? #138
Good to here from you 14. Misted you there for awhile. Do you have a picture you can post of that?
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
John Deere M665 Zero Turn Mower (A55851)
John Deere M665...
1111-A (A54756)
1111-A (A54756)
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
