PT ABUSE?!!?
   / PT ABUSE?!!? #1
FOURTEEN
Veteran Member
Efland - Triangle of North Carolina.
2004 Power Trac PT-425
PT Abuse. Does it happen? Is that good or bad?
“noun: improper or excessive use”
What is ‘improper’? If I can get my PT to do a job that it wasn’t specifically intended for, isn’t that just innovation? I dig up stones rather than potatoes with my Potato Digger. I cut trenches with my Stump Grinder. Are those uses improper?
What is ‘excessive’? Is moving 50 big logs OK, but moving 100 big logs excessive? If I try to lift too much, my PT just won’t do it! Nothing bends or breaks, it just refuses! What’s the largest lawn that I can mow without abusing my PT?
“verb: change the inherent purpose or function of something”
The best virtue that a PT has is it’s ability to help it’s owner with nearly any job he has to do! Most Posts here on TBN involve talking about how to get a variety of jobs done using the PT, about how to use the PT in unusual ways, or about how some change or improvement will allow the PT to work even harder and better!
My test is if what I am doing will lead to bending, breaking, failing, accelerated wear, or damage! If not, it’s not ‘abuse’!! With all the ‘abuse’ being reported on TBN, why do I see so few Posts about PT failures??
In nearly 3 years of abusing my PT the only possible ‘abuse’ failure that I’ve had was the bending of the toggle between the lift arms. But the replacement toggle that PT sent me was much larger in diameter! So maybe it wasn’t my abuse, but rather the OEM sizing of the toggle that was to blame for the failure!!
To paraphrase the old Timex commercials: “The Power Trac will take a licking, and keep on ticking!!”!
   / PT ABUSE?!!? #2
I agree with Fourteens point 100%. If anyone has abused their PT beyond its intended purpose I guess I would have to fess up first and jump in front of the line. The 180 was not designed to handle a mini backhoe ( at least that's what I was told by powertrac when I approached them about the idea ). Eighteen months later and the backhoe is still working like a true trooper, even with the 16" bucket! Am I stressing or abusing the machine-- so far nothing has broken yet!
I reversed the stump cutter and have had no damage to the machine, plus I'm not getting a face full of dirt and woodchips. Now if someone is stupid enough to stand in front of or beside the stump cutter while it's running I guess that would be a unsafe practice.
I built the carryall for the 180- is the extra 75 lbs. putting stress on the wheel motors and motor brackets? I don't think so, if anything the added weight helps for traction.
I built the hydraulic boom lift as well, and while I don't intend to lift 6-700 lbs.12 feet in the air with it, it has come in handy several times.
The only thing I would not do is reverse the wheels, because where I only have one steering cyl. I do believe that would put undue stress on the steering cyl. bracket weldments.
Anyway that's my story and I'm sticking to it.
   / PT ABUSE?!!? #3
I believe that abuse is indicated by doing something that shortens the life of the device by many times. If I use an attachment and it breaks after 10 minutes then I probably abused it. PT has the relief valve to protect against overloads and that keeps you from lifting something too heavy, or grabbing something too hard.
If I can fix the abuse quickly with the tools that I have at hand and not buy an expensive part then I don't feel too bad.
The problems I have had the most was getting something caught in the shaft seals of the hydraulic motors on the trencher and stump grinder. On the stump grinder it as a root or vine. I feel that roots are a normal part of the world and the PT should handle that. On trencher it was a strap. This was my fault and I should have kept the strap away from the trencher.
The other philosphy is to never use the product. It wil last a long time, but what is the point of owning it if you don't use it. If you wear it out the day before you die, that's about right.
   / PT ABUSE?!!? #4
I have broken two sledge hammers in my life... not the handles, the head. I beat them into a bent up piece of steel. I was using them beyond their capability. I do believe we can overstress the PTs; the motors, the welds and the designs, by constantly adding more weight to the units and pushing against immovable objects too often. Something will give eventually.
Yes, I will just fix it when it does. But I maintain that we PT owners push these things much harder than what they were designed for.... and don't give a hoot! :D
   / PT ABUSE?!!? #5
MossRoad said:
I have broken two sledge hammers in my life... not the handles, the head. I beat them into a bent up piece of steel. I was using them beyond their capability. I do believe we can overstress the PTs; the motors, the welds and the designs, by constantly adding more weight to the units and pushing against immovable objects to often. Something will give eventually.
I guess my use of the 425 digging a foundation was by far excessive abuse.
On the other hand it did the job even if slow. When I was finished I had saved $2500 which more than paid for the mini hoe.
PJ
   / PT ABUSE?!!? #6
I do care about my PT and all of the equipment that I own. I only have so much money and would like to use if effectively. Watch for the running starts into a pile of dirt or similar. It is easy to abuse a PT since the manufacturer cannot predict all possible uses and abuses.
Also since PT has no warning on what is abuse, one man's idea of what is normal use may far exceed the machine capability. TBN can certainly help.
I suggest we focus this thread on what we consider abuse. Let's stay away from reversing the wheels discussion since that has been done to death. What have you personally done that turned out to be abuse and damaged the machine or significantly shortened the machine life or you just knew this was not right. Then people can make up there own mind if the want to take the risk.
I pushed on a tree with the quick attach plate (no attachment connected). The plate was warped and since then I have had to straighten it out with a hammer and reweld both of the bolts that go through the plate and hold the connect lugs in place. I did not think this would hurt the machine when I did it. I would definately not do this again.
   / PT ABUSE?!!? #7
I guess I like to baby my PT most of the time. As Bob mentioned above, I don't ram the bucket into anything, I take my time, work with the machine and stay within its limits. The job gets done a little slower, but it gets done just the same.
I do on occasion lift or move overly heavy objects. Of course that’s why I bought the PT. When in use I make slow smooth steady movements with the controls. If lifting, turning or traveling with a full load I try not to jerk it.
When I’m done working I always do a check for anything loose or bent, and tighten accordingly. Then again I treat my truck, and all of my equipment that way. This is probably the only tractor I will ever buy. I want it to last a long time.
   / PT ABUSE?!!? #8
I think my original boom lift design put the most stress and abuse on my attachment plate. If some of you remember my orig. boom lift thread, I made the attachment frame with a vertical receiver and a receiver 90 degrees to the plate. This was a bad idea because when I was lifting weight at the end of the boom ( distance to the tip of the boom is 52" ) the tilt / curl cyl. was straining. So now I let the hydraulic boom do the work instead of the attachment plate cyl.
   / PT ABUSE?!!? #9
I wondered about this issue before I bought my 425 and asked the wise folks here about it in this thread http://www.tractorbynet.com/forums/power-trac/36867-pt-abuse.html?highlight=abuse. After putting over 200 "hard" hours on my machine, I believe I've had to fix a number of things that wouldn't have been necessary if I'd just been cutting grass or other "easy" tasks. I moved and spread over 150 dump truck loads of fill dirt on my lot and had to make a number of repairs that I think were directly related to that task. Do I think I abused my PT? Well, maybe...but I say it with pride, and all my neighbors are amazed....Especially when she's under full load and doing the PT pucker.
   / PT ABUSE?!!? #10
My modified boom lift puts less strain and abuse on my attachment plate and the tilt/curl function.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
7046 (A50322)
7046 (A50322)
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
