pt attachments on other traction units
   / pt attachments on other traction units #1
agjones
Platinum Member
Jessup Mill, NC
Rk55HC, Kubota kx040, power-trac 425d, Bobcat L23, Yanmar 401w, bx1880, IHI 30 and Fiori D40 dumpers, Magnatrac mh5000, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
After a few years w pt attachments that, to me, have stacked up well to other manufacturers while handily beating them on price (looking at you toro), I've converted a few different tool carriers/traction systems to use the PT quick attach setup.
First was a magnatrac mh5000 dozer. It's now remote controlled.
Next came the toro dingo, because forget those bendy qa pins and spendy attachments.
Now, I've got 3 conversions on deck and wanted to share the inputs and results.
Next up: is a Mcelroy tracstar 28...some kind of pipe/conduit fusing tool carrier. Idk what it was just the specs... The unit I scooped up is Rubber tracks and hydraulics ready to drop a Honda gx390 (11-13 hp) on... plenty of power for traction, cylinder based attachments (grapple, minihoe) and stationary pto tasks, I'll give the stump grinder a go,trencher not so much. Brush cutter, nope.
It's getting pt arms and qa, a dedicated limb chipper, 4 gpm chainsaw/polesaw/generator circuit, 50' dual hyd hose reel and a 20' man lift w outriggers. Yep, I'm well insured.
After that (assuming there are survivors) a terramite t5c carcass that will be merged with the running gear and power plant of a ransomes 250 fairway mower to become a 4wd, pt 4 series tool carrier and backhoe.
Finally a lay-mor towable sweeper... What? Yep.
I think of it as repurposeful equipment. I recycle my beer bottles, why not machines?
   / pt attachments on other traction units #2
Awesome!
Please share the conversions as they happen.
Where do you find the carcasses? They are a bit thin on the ground hereabouts.
All the best,
Peter
Awesome!
All the best,
Peter
They come from all over the place... A few ppl with eyes out at scrap yards(whole toro dingo $75=personal record) , golf courses are a great supply of Kubota and hydraulic stuff.
The other day on ebay I got a helac cylinder (Google it hard to explain)... 90$ (usually thousands) now my backhoe is getting a tilting bucket. Huge work saver for me... Couldn't afford it otherwise.
If you learn to read those obnoxious part numbers on hydraulic stuff...there's tons of cheap pressure&flow gizmos in ebay from surplus and liquidators.
Ebay, craigslist... I find abandoned projects or 'don't have time to fix' stuff all the time.
Idk what happened in the hydraulic world but there was a ton of cheap valves and such on Amazon. I Search cross and prince valves on Amazon, every now and then... 32$ proportional valve 66$ 2 spool w float... Never know.
Can't wait for the pictures. :thumbsup:
My pt425 with the Kubota and 3pt hitch thinks it's name is 'what - the hello- is that'
Franken family photo coming soon!
I do a lot of work around DOT projects and in this yard or that I find that the 'girl in the office' is often given a list of stuff to get rid of... Even better I find that person doesn't know what it is... 50 lay-mor sweeper w 33 Kubota hp... Missing only a cheap part.
   / pt attachments on other traction units #8
That's the nice thing about commercial/industrial equipment. It was super expensive new and the quality and design usually reflect that. It's not just consumer stuff made as cheap as possible to be just enough. Also, a lot of stuff is common and generic. Not special to a particular machine. Ritchie always has some back row of weird stuff like that.
Some of the stuff that goes to scrap just makes you want to cry.
   / pt attachments on other traction units #9
I've been to a few Ritchie Bro. Auctions. There can be a whole buncho potpouri there.
   / pt attachments on other traction units #10
You pay mostly in your time, which can be a very long day.
Linde H35D 4,350lb Forklift (A49346)
Linde H35D 4,350lb...
2011 FORD F-650 SUPER DUTY (A48992)
2011 FORD F-650...
(4) Sumitomo 11.00 R22 Tires (A48837)
(4) Sumitomo 11.00...
8 Ton Running Gear (A49251)
8 Ton Running Gear...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A48837)
New/Unused 7ft 20...
2011 Ford Escape XLT SUV (A48082)
2011 Ford Escape...
