ponytug
Super Member
Low hours?
Not entirely kidding; seals need some amount of movement to stay lubricated, and if they sit for a long period of time in one position, the rubber seal can bond to the metal.
I think more likely is that there was some particles in the cylinder from when it was made that didn't get flushed out with use. Hydraulic systems are assumed to be perfectly clean when they are built, but...there is sometimes material in a hose, or a cylinder that ends up someplace that causes a problem before the filter catches it.
So...if you keep things clean during the rebuild, you should end up better than new.
Good luck,
All the best, Peter
Good luck,
All the best, Peter
