PT425 lift capacity
   / PT425 lift capacity #41
<font color="blue"> ohhh yeah mr i also have the added benefit or detriment of weighing 320 lbs wonder if that has anything to do with it all that extra counterweight </font>
LOL!!! That's 110 more than me @ 210 /forums/images/graemlins/grin.gif A little counter weight goes a long way. /forums/images/graemlins/laugh.gif
   / PT425 lift capacity #42
Would the 4 in 1 bucket do the same thing (maybe)?
Has anyone here bought BOTH the grapple bucket and the 4 in 1 bucket?
Yooper Dave
   / PT425 lift capacity #43
<font color="red"> what is borium </font>
Don't you hate it when Bubenberg does that. Puts a teaser in a post, then disappears for a while. /forums/images/graemlins/tongue.gif
Borium is tungsten carbide, which farriers use a fair amount in horseshoeing. It comes, as I understand it, with mild steel sticks, so you can weld it on horseshoes or any other steel to give a very hard layer. I've not used it, since you can also get it on studs that screw into horsehoes for those few times when traction on roads or rocks is a problem. I have heard of using it on digging teeth, and have heard of hard steel and borium welding in the field on commercial digging and trenching equipment, but haven't seen it done.
Anyone other than Bubenberg have borium experience?
   / PT425 lift capacity #44
Charlie already answered your question but here is what i learned back in the cavalery school in Switzerland and it became part of my lectures to bored college students here in the USA. This is where i get it from!
The Horse Shoe Barn
the paper has turned yellow: Borium is tungsten carbide shaped into a soft steel rod 1/8" to 1/4" thick. To apply borium to a shoe, you need a set of acetylene welding torches, welding glasses, welding gloves, a safe work area, and the skill and training to weld. To follow these instructions, you have to already know how to weld. Shape the shoes to fit the hooves, just as you would for summer shoeing. Before you nail the shoes on, add the borium as follows: Stack the shoes on top of each other, which helps avoid wasting heat. As you add borium to the top shoe, the next shoe down heats up, as well.
Work on one spot at a time. Add a spot of borium to each heel and two spots at the toe, just ahead of the first nail hole. Get the spot up to welding heat and heat the borium rod at the same time. When the steel begins to puddle, pull the welding tip away, adding borium as you go back and forth with the welding tip and the borium.
For a little traction, make a short spike; for more traction, make a taller spike. Adding borium takes a good amount of skill and practice, but the flexibility of its placement on the shoe and the excellent traction it offers make borium a good choice.
   / PT425 lift capacity #45
some other sources:
Centauer Forge
Thermadyne
Pyramid Alloys, Inc.]Pyramid Alloys, Inc.
This last outfit explains in detail the use of borium with:Heavy Equipment, Mining Equipment, Snow Removal Equipment, Farming etc
and so that Charlie get's off my back, they include a rather well written: The History of Tungsten /forums/images/graemlins/tongue.gif
we are back to the old grind stone for the next 9 month (lawn care, topdressing, light demolition, land clearing, fencing and all the other happy h.... s...) have a good growing season and get that borium.
for equipment use you don't have to be that good of a welder, but it can save you alot of wear and tearm on your equipment !!!!!!!!!!!! /forums/images/graemlins/grin.gif
   / PT425 lift capacity #46
There is a saw mill near my home that has a large machine looks like it has a set of forks on it. They scoop under the logs and they have a grapple that swings down over the load just like the grapple on your bucket does. I have seen them get several logs at the same time with no problem. I would think it would be easier to pick up brush withthe forks and grapple to hold it on.
   / PT425 lift capacity #47
<font color="blue">My neighbor, Danny, who has owned 63 tractors so far and usually spends several hours a day on one, immediately upon trying my Grapple Bucket remarked that it needed sharpening! He has achieved excellent results by grinding every edge, bottom and sides of buckets, and sides of rock teeth, with a chisel-like one bevel 45 degree cut, like a lawnmower blade. </font>
Hey, Fourteen!
I pulled out the grinder and sharpened the blunt nosed rock teeth to a 45 degree angle. Made a very noticeable difference. So much so, that I transplanted two forsithea bushes with easy. First, I pointed the toothed bucket down and jammed the teeth into the soil. By applying down pressure and rocking the joystick side to side while dancing on the treadle pedals(my favorite pallet fork method), I was able to get the little bucket completely burried. Then it was just a mattter of curling it up while operating the pedals and I popped out a perfect bucket full of soil. I set it aside, then went and did the same thing under the bush. Popped it out and put it in the exact duplicate hole that I had dug. Picked up the pile of soil and replaced it in the hole where the bush was. Repeated for the second bush. Took all of 5 minutes to transplant both bushes.
Thanks for the tip! I recommend it to anyone with the factory rock teeth. By the way, I used my $14.95 el cheapo Harbor Frieght grinder to do it. Took about 2 minutes per tooth. /forums/images/graemlins/wink.gif
   / PT425 lift capacity #48
Thanks!! Glad to hear from someone who has had positive results trying one of my ideas!!! /forums/images/graemlins/cool.gif I take all the credit, and all the blame!! /forums/images/graemlins/blush.gif
The more common responses seems to be: "This guy is
!!" or "What would I want to do that for!!??!!" or "Does PT approve??" or "Don't you dare tell people what they should do!!"!!
I've got more ideas, but, so far, I have been too shy to propose them!! (None of these require the use of firearms!!)
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / PT425 lift capacity #49
Here is a picture (??) of my 422 with a bucket full of firewood that I cut the other day. It is more than I can get on my wheel barrow.
   / PT425 lift capacity #50
try again
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
