PTO Auger vs post pounder
   / PTO Auger vs post pounder #1
rockingclawhammer
South Texas
Case 485, MF 265, Kabota 26hp
I am considering the pounder HD-8 or the ETA 7500. My soil ranges for deep sand to very hard clay. If going with the pounder, I would use 2-3/8" or 2-7/8" pipe. For the Auger I use RR ties or big cedar posts. It will be mainly a 1 man operation. Which would you choose and why? I have many years experience with the PTO augers and none with the pounders.
   / PTO Auger vs post pounder #2
Where I am in Southern Illinois it is clay soil and some rock. I've used both and you will not drill a hole and set a post near as solid as what you can pound one in with an HD8. With the 2 3/8" or 2 7/8" pipe it will go in with ease and I'm not even sure rock would get in the way. The railroad ties will pound in but I prefer to wait until the ground is really soft in the spring or after alot of heavy rains, you really can't be too muddy for the post driver to not work well. That being said when the ground is hard and dry my post driver struggled with a 4x4 wood square post, with softer ground I drove a 6"x8" post in the ground as well as two 6x6 posts and had the entire corner structure built in maybe 30 minutes.
   / PTO Auger vs post pounder #3
Well - - seeing as my experience is with T-133 fence posts and rail road ties. I'd say you would have to be more of a man today than I was 36 years ago. Thats when I installed the five strand barbed wire fence around my 80 acres here. I used full sized RR ties at some of the strategic points and interspersed along the runs. It was MORE than a PITA getting those RR ties into the holes I dug - but now 36 years later they are still just as solid as the day I installed them.
There are many places along my property line where absolutely NO TYPE of vehicle could access. Ravines and steep hill sides. All my T-133 were pounded in with a manual pounder. Took me a year and a half to get the fence installed. Working by myself, in the evenings after work and on the weekends. With normal maintenance - still stands - rock solid today.
   / PTO Auger vs post pounder #5
I've seen a couple VERY serious accidents with very large industrial augers. Where the auger bound up and the big 'ol U-joint broke and went flying. Not a friendly situation. One where a half of the U-joint blew right thru a brand new Cadillac parked about 100 feet away. There was a unique moment of silence on that work site.............
   / PTO Auger vs post pounder #6
If you're sure that there are no big rocks and or roots (or other such submerged materials) and there's room to operate then a post-pounder would be the way I'd go. I just fenced in the homestead area, about 2,100 feet of fencing, but ran an auger (skid steer) and hand tamped/set the posts. One would be hard-pressed to haver gotten a better set with pounded posts: I used altering layers of material and the stuff set up like concrete. Had two holes that I really struggled with, one required picking another spot (hit some deep buried cedar trunk [where there were no such trees!]) and the other was a bunch of big rocks in driveway fill (ended up with a huge hole); the later would have proven impossible for a pounder- this was an end post on my main driveway gate in which case it was NOT going to be relocated! The ground I was going in to varied quite dramatically: some fill area with huge rocks; fill area that was mostly sandy; one area where, in the middle of summer I hit water at about 1 1/2' (my layering of materials allowed me to provide for better anchoring, something that just pounding in a post wouldn't have done).
I figured my per hole cost to be about $3, for the rental of the skid steer: about 110 holes in 2 days.
I believe that the rental cost skid steer rental came out to be about $3/hole. That's for about 110 holes at 4' deep.
   / PTO Auger vs post pounder #7
Fore reference on the driven posts, I put a 6x6 in the ground a shade over 3' deep and I couldn't lift it out with my 55 hp Ford utility tractor on the loader. It will lift just about anything but wouldn't budge that post.
   / PTO Auger vs post pounder #8
6x6 presents a LOT of surface area. If it's clayish soil there is a LOT of drag.
Issue/concern is also lateral give (especially for line posts).
   / PTO Auger vs post pounder #10
I had a pounder, but never driven pipe, depending on your soils I would think that the pounder is the way to go over an auger. What do your neighbors use? A driven post is as tight as it gets.
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A54756)
UNUSED CFG...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
FORD 7710 TRACTOR (A54756)
FORD 7710 TRACTOR...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
