PTO clutch won't disengage
   / PTO clutch won't disengage
Re: PTO clutch won\'t disengage
Guess I should check this more often.
TDI, this was my first tractor buying experience; I didn't even know about that "halfway bolt" until this year and yes, it was turned down; that's why I never knew it wasn't right. The pedal went down far enough to disengage the clutch until I adjusted it to specs. I've put about 300 hours on it since I bought it 4 years ago from the guys out there on Hammond St Ext; this year little things are starting to crop up.
Warm weather's coming, /forums/images/graemlins/cool.gif then I'll ,make time to get things straightened out.
   / PTO clutch won't disengage #22
Jstpssng, An old mechanic told me that sticking clutches used to be a common problem, particularly if unused for a period of time. He recommended spraying the plates with kerosene. I've used it successfully on a Farmall A and my old Dodge woods truck, both of which can sit for several months without use. The kero penetrates the rust bond between the clutch plate and the flywheel but doesn't provide enough lubrication to cause slippage.
   / PTO clutch won't disengage #23
I am impressed with 3 1/2 hours. The bucket brackets took me a while, but even then it was almost two hours to get apart for me. Then at least an hour of head scratching trying to figure out what the crazy noise is I am looking for. Still haven't figured that out. Sounds like something, maybe a spring, bouncing around in there. When I get the loaner clutch alignment tool I will strip the clutch and see if maybe one of the plate springs wanted a vacation.
Loegering Metal Tracks (A50774)
Loegering Metal...
Land Honor Skid Steer Blank Plate (A50514)
Land Honor Skid...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
